bad idle Help! posted by Ugaucin on June 24, 2012 at 03:14 PM
Bad idle is can a be bad air regulator valve clean that and the electric connectors if is sitting for 2 years all the connectors can be ugly also the water temperature sensor can make you bad idle good luck
